by crfsonly » Wed Mar 26, 2014 8:21 am
not sure i understand your question. but a full system from PC, or other manufacturers, includes a header/mid pipe. so, the manufacturers aren't constrained by the pipe diameters of the stock header/mid pipe or muffler. neither are they constrained to the location of the mid pipe/muffler connection. if yours is a full system from PC and they can get you a replacement header for it then it will fit perfectly/as designed. most after market systems i am familar with are slip on (no clamp/gasket) at the mid pipe/muffler connection. some will use springs but no clamp.
