by crfsonly » Tue Aug 20, 2013 1:41 pm
yes, opening up the air box, free flowing air filter, jd jetting kit, free flowing exhaust will help. however, this will only take you so far and then the cam grind, head and ignition will limit yours from reving "like" a 450R (if that's your goal). drop in a R cam and do the pink wire mod in addition to the other mods and it will help on the top end. you can also switch to a R head when the time comes for valve or head work.
