by JimDirt » Thu Jun 13, 2013 2:54 pm
If its the same as the 450X (i do not have a 250X manual so i cant confirm) , it should have a Starter Clutch , which is located behind the regular clutch (you have to remove the right side crankcase cover , the clutch and it should be the back gear in the assembly that drives the main clutch , Remove the primary drive gear bolt, washer, clutch
outer, needle bearings, clutch outer guide and primary
drive gear. , it is a 1 way gear
DISASSEMBLY/INSPECTION
Check that the starter driven gear turns counterclockwise
smoothly and does not turn clockwise.
Remove the driven gear and needle bearing from
starter clutch outer.
Remove the snap ring and one-way clutch from
clutch outer.
Check the needle bearing for abnormal wear or
damage.
Check the starter driven gear for abnormal wear or
damage.
Measure the driven gear boss O.D.
Measure the driven gear boss I.D.
Check the one-way clutch sprag for abnormal wear
or damage.
Check the starter clutch outer sliding surface wear
or damage.
Check the reduction gear A and idle gear for wear or
damage.
Measure the reduction gear A I.D.
Measure the idle gear I.D.
NEEDLE BEARING
SERVICE LIMIT: 45.660 mm (1.7976 in)
SERVICE LIMIT: 36.034 mm (1.4189 in)
ONE-WAY CLUTCH
CLUTCH OUTER
SERVICE LIMIT: 12.050 mm (0.4744 in)
Hope that helps some
