New wheel, lubricate spokes?
    RamboEinar
    by RamboEinar » Sat Mar 02, 2013 6:07 am
    Hello :)
    Just got my new DNA wheel set. Its pre mounted and ready for some tires. But should i loosen the spokes and add some lubrication on the threads before i mount tires? I think it will be easier to tighten the spokes later. It's the first time i'm doing this so need some tips from you who probably have done this for years :D
    motosicko
    Re: New wheel, lubricate spokes?
    by motosicko » Sat Mar 02, 2013 7:23 am
    RamboEinar wrote:Hello :)
    Only if you ride through water often. A little penetrating spray on ends of nipples inside rim will do. Keep a good tab on spoke torque every ride.
    "There are old racers
    and there are bold racers,
    RamboEinar
    by RamboEinar » Sat Mar 02, 2013 6:00 pm
    Ok, so if i check and tighten the spokes regularly they should not seize up? On my old rims the spokes are bad and probably seized..
    I guess i need to replace them.
    motosicko
    by motosicko » Sat Mar 02, 2013 8:48 pm
    Like all parts on your CRF, regular maintenance needed to keep from seizing up. Dissimilar metals are the worst for locking together and require attention more often.
    Not a bad idea to loosen and re torque spokes every now and then. Do it one at a time every 3rd spoke around the rim 3 times, just the same as when you tighten spokes.
    RamboEinar
    by RamboEinar » Sun Mar 03, 2013 3:07 am
    Thanks for the help! :D
    How much torque should i apply to the spokes? I got on of these spoke torque wrenches. 6Nm?
    by crfsonly » Sun Mar 03, 2013 9:26 am
    keep a close eye on these wheels. we tested them and besides spoke issues the bearing expired very quickly.
    RamboEinar
    by RamboEinar » Sun Mar 03, 2013 10:58 am
    What type of spoke issues did you find? I have heard people put 100-300 hours on them without major problems.
    2007 CRF250R
    by crfsonly » Sun Mar 03, 2013 3:04 pm
    spokes difficult to keep correctly torqued and the bearings didnt' last long.
    RamboEinar
    by RamboEinar » Sun Mar 03, 2013 3:51 pm
    I will keep that in mind, and let you know if something happens, with my riding style i think they are up for the task :)
    2007 CRF250R
