2003 CRF230F keinhin PD9CA carb questions
  • Jjjjohn22
    by Jjjjohn22 » Tue Jan 15, 2013 7:38 pm
    Does the slow jet suppose to be hollow from the slotted bottom all the way thru the top where the holes are located?
    Also in addition to the slow jet being screwed in, is it also seated thru a rubber gasket at the ribbed end? It unscrewed, but took some force to pull out of opening.
    Thx
  • Jjjjohn22
    by Jjjjohn22 » Wed Jan 16, 2013 5:22 pm
    Ok, I'll answer my own question. Yes, slow jet should be hollow, mine is completely clogged, new one ordered.
    No, there should not be a rubber ring/gasket inside where slow jet is located, seems previous owner put 1 here, I removed it.
    by crfsonly » Wed Jan 16, 2013 9:09 pm
    Welcome to CRF's Only! My apologies that I didn't see your original post. Glad to hear you have it worked out.
    Again, welcome.
    Ken
