crfs only "T" FS screw
    leirhiht
    by leirhiht » Sun Dec 16, 2012 11:01 am
    so i got the crf's only T fuel screw and i am wondering if i can just install it according to my manual. which is 1-3/4 turns out. or is there another setting i need to use?
    ive got an 06 crf250R
    by JAWS » Sun Dec 16, 2012 11:09 am
    Good place to start and tune from there.
    by crfsonly » Sun Dec 16, 2012 1:17 pm
    as mentioned...it's a good place to start. make sure you install it with the o-ring, washer and spring. if the spring is compressed when removed stretch it out. it's the spring tension that will keep the fuel screw from backing out.
  • therooster70
    by therooster70 » Mon Mar 18, 2013 5:38 pm
    I also found a fat rubber band and wrapped it around the fuel screw and a bolt on the engine once I had it set where I wanted it. Just light tension...u don't want to bend the screw shaft. Matt
    Matt
