throttle tight/sticking
Posted: Fri Nov 30, 2012 10:17 am
by crtwd95
2006 crf450r and throttle is wicked tight and doesn't snap back. How do I loosen it up?
Posted: Fri Nov 30, 2012 5:27 pm
by edge22
I would try getting a cable luber and some cable lube. When you get that first take some brake cleaner and spray through the cables then the lube. If that doesnt loosen them up you will need new cables.
Posted: Fri Nov 30, 2012 6:22 pm
Grease, dirt, grime builds up under the throttle tube & you loose that snappy feeling also.
Like Edge stated - cables need a little love too.
If you have guards make sure the drag is not at the grip end also.
Posted: Sat Dec 01, 2012 2:43 am
by crtwd95
Thanks. I'll try that.
