Bike will not crank
  • chance012
    Bike will not crank
    by chance012 » Sat Jan 14, 2012 1:42 pm
    traded for this bike about a month ago, got it home and tried to crank it and it felt like it had no compression, which was weird, it was hard to crank but it did crank and ran the day of trade. i did a little bit of research and was advised to check my valve clearance, when i went to check the valves the intake was very tight and my exhaust was all the way open. i put the proper shims in to give it the proper clearance for each. bike ran great after that it cranked within 10 kicks, i did the proper break in process everything was fine, i tried to crank the bike today. ( a week later) and the first 5 kicks the bike acted like it wanted to start then sounded like a backfire and the bike doesn't feel or sound like it wants to crank.
  • staffy24
    by staffy24 » Sat Jan 14, 2012 5:59 pm
    valve job needed after a reshim you will only get 2 or 3 hours
    over 40 still ridin hard
    still learning
  • chance012
    by chance012 » Sun Jan 15, 2012 6:05 pm
    is it always just a temporary fix? one of my friends shimmed his last year and his bike is still running great he rides at least every other weekend.
