front wheel
    front wheel
    by [email protected] » Sun Dec 25, 2011 10:51 pm
    removed front wheel on my 450xi for maintence,reinstalled wheel per service manuel protocol and the wheel will not spin this is a list of what has been replaced to resolve problem new wheel,new axle, new brake pads service manuel specs for axle is 65ft lbs l/r pinch bolts are 14 one side and 15ft lbs the other.cant figure out why this is happing any suggestions
    by Back2-2 » Mon Dec 26, 2011 6:14 am
    May start by removing the brake caliper and see if the resistance is in the wheel or the brake assy.
    work backwards to find where your problem is.
    question : Did you torque the pinch bolts first, then the axle nut ? If not, you may have the wheel hub in a bind. But first start with the brake caliper removal.
    Good luck -you'll find the problem.
    motosicko
    by motosicko » Mon Dec 26, 2011 7:28 am
    Wheel spacers correct? The brake rotor bent? Look at the gap in the caliper and make sure the rotor is centered and not binding to either side.
    "There are old racers
    and there are bold racers,
