2006crf250 header glowing very red
Posted: Sun Dec 25, 2011 6:10 pm
by Nstyle
Hey guys.. I have a problem with my bike that every time I start it almost 30 seconds after the header starts to glow very brightly.. It was 40 degrees when I did it..but it's been doing that all winter..could it be running leen from the cold air?
Posted: Sun Dec 25, 2011 10:16 pm
by staffy24
yes lean have you done any work lately may have an air leak or need jet change or ajust
Posted: Mon Dec 26, 2011 1:14 pm
by Nstyle
Only thing done to it is the baffles r removed.
Posted: Mon Dec 26, 2011 8:02 pm
that can lean it out so you'll need to richen the pilot circuit up at least. also, don't let it idle for long on the stand. needs air flowing through the radiators to keep from overheating.
Posted: Tue Dec 27, 2011 8:30 am
by Nstyle
thanx guys I'll have to mess with it today ..would it be the fuel air screw on the carb?
Posted: Tue Dec 27, 2011 12:31 pm
fuel screw is on the bottom of the carb (float bowl) area. in the photo below it's the brass screw (yours may be a different screw but in the same location)
Posted: Tue Dec 27, 2011 2:27 pm
by Nstyle
Wow awesome info..thanx a lot ..mine shouldn't be that different it's only an 06
Posted: Tue Dec 27, 2011 2:30 pm
by Nstyle
Should I adjust it when runing
Posted: Tue Dec 27, 2011 2:53 pm
setting the fuel screw mixture-
adjust the fuel screw when the motor is at full operating temperature. turning the fuel screw inwards until the idle slows or runs rough, then turn outwards 1 1/4 turns from this position. For example, if the idle slows or runs rough at 1/2 turn from closed, then set the fuel screw to 1 3/4 turns out (1/2 + 1 1/4 = 1 3/4).
hope this helps.
Posted: Tue Dec 27, 2011 7:00 pm
by Nstyle
It does..a lot actually..thanx!
Posted: Tue Dec 27, 2011 7:24 pm
by Nstyle
Sorry I have one more question then I'll get off the case..there is this tarnish like substance on my frame and engine that i can't get off. The previous owner kept it In his very damp garage...do u have an idea on what I could do with out altering the color of the frame
Posted: Wed Dec 28, 2011 3:39 am
by staffy24
acid for alloy
Posted: Wed Dec 28, 2011 5:50 am
by Nstyle
Where would i find that?
Posted: Thu Dec 29, 2011 8:43 pm
by staffy24
auto parts shop 1 ltr bottle make sure you follow instructions not to let it dry on. and use some thing like amour all afterwards or wd 40 you mite have to do it a couple of times even 3 to get it good just mix and spray
Posted: Thu Dec 29, 2011 8:45 pm
by Nstyle
Thanx a lot! I appreciate the help.
