2006crf250 header glowing very red
  • Nstyle
    by Nstyle » Sun Dec 25, 2011 6:10 pm
    Hey guys.. I have a problem with my bike that every time I start it almost 30 seconds after the header starts to glow very brightly.. It was 40 degrees when I did it..but it's been doing that all winter..could it be running leen from the cold air?
  • staffy24
    by staffy24 » Sun Dec 25, 2011 10:16 pm
    yes lean have you done any work lately may have an air leak or need jet change or ajust
    over 40 still ridin hard
    still learning
  • Nstyle
    by Nstyle » Mon Dec 26, 2011 1:14 pm
    Only thing done to it is the baffles r removed.
    by crfsonly » Mon Dec 26, 2011 8:02 pm
    that can lean it out so you'll need to richen the pilot circuit up at least. also, don't let it idle for long on the stand. needs air flowing through the radiators to keep from overheating.
  • Nstyle
    by Nstyle » Tue Dec 27, 2011 8:30 am
    thanx guys I'll have to mess with it today ..would it be the fuel air screw on the carb?
    by crfsonly » Tue Dec 27, 2011 12:31 pm
    fuel screw is on the bottom of the carb (float bowl) area. in the photo below it's the brass screw (yours may be a different screw but in the same location)
  • Nstyle
    by Nstyle » Tue Dec 27, 2011 2:27 pm
    Wow awesome info..thanx a lot ..mine shouldn't be that different it's only an 06
  • Nstyle
    by Nstyle » Tue Dec 27, 2011 2:30 pm
    Should I adjust it when runing
    by crfsonly » Tue Dec 27, 2011 2:53 pm
    setting the fuel screw mixture-
    adjust the fuel screw when the motor is at full operating temperature. turning the fuel screw inwards until the idle slows or runs rough, then turn outwards 1 1/4 turns from this position. For example, if the idle slows or runs rough at 1/2 turn from closed, then set the fuel screw to 1 3/4 turns out (1/2 + 1 1/4 = 1 3/4).
    hope this helps.
  • Nstyle
    by Nstyle » Tue Dec 27, 2011 7:00 pm
    It does..a lot actually..thanx!
  • Nstyle
    by Nstyle » Tue Dec 27, 2011 7:24 pm
    Sorry I have one more question then I'll get off the case..there is this tarnish like substance on my frame and engine that i can't get off. The previous owner kept it In his very damp garage...do u have an idea on what I could do with out altering the color of the frame
  • staffy24
    by staffy24 » Wed Dec 28, 2011 3:39 am
    acid for alloy
    still learning
  • Nstyle
    by Nstyle » Wed Dec 28, 2011 5:50 am
    Where would i find that?
  • staffy24
    by staffy24 » Thu Dec 29, 2011 8:43 pm
    auto parts shop 1 ltr bottle make sure you follow instructions not to let it dry on. and use some thing like amour all afterwards or wd 40 you mite have to do it a couple of times even 3 to get it good just mix and spray
    still learning
  • Nstyle
    by Nstyle » Thu Dec 29, 2011 8:45 pm
    Thanx a lot! I appreciate the help.
