by scotsy » Tue Dec 13, 2011 11:37 am
360 degrees out is more likely = one complete rotation of the CRANKSHAFT
The crank and cam marks should be lined up and the inlet lobes of the cam will be pointing 'up' and 'rearward' when you've got it right so there will be clearance on all the valves.
This is TDC on the compression stroke
Ian
