Lacquer in carb
  • kevpilot
    Lacquer in carb
    by kevpilot » Mon Dec 12, 2011 1:35 pm
    My CRF 70 sat too long. I pulled the carb off, removed the bowl and the fuel smells like lacquer. There is a bunch of golden-brown colored deposits in the bowl and carb...so......what is the best "solvent" to soak the whole thing in to dissolve the deposits? I tried kerosene and it got off some but not much.
    Thanks
  • taylorrep
    by taylorrep » Mon Dec 12, 2011 2:57 pm
    Yamaha Combustion and Chamber cleaner is what my mechanic uses and it works exceptionally well.
    Daniel
    by Back2-2 » Mon Dec 12, 2011 3:06 pm
    Any of the spray carb cleaners work well. Walmart, checker auto, Pepboys ect...
    Wear safety glasses - it loves to blast back into your eyes when you want just a little squirt. Carb cleaner & a tooth brush / acid brush should clean those parts up. The jets are going to need to be cleaned out also. Special attention to the pilot jet ! Really small orifices.
    Good luck & hope that helps.
    by crfsonly » Mon Dec 12, 2011 4:26 pm
    just remember that carb cleaners often damage rubber o-rings and seals. so use it while the carb is apart and with the rubber o-rings and seals removed.
  • staffy24
    by staffy24 » Mon Dec 12, 2011 11:49 pm
    better to replace rubber and jets
    over 40 still ridin hard
    still learning
    by Aussiecrf230 » Tue Dec 13, 2011 4:33 am
    Better still we drain our float bowls after washing our bikes.
    Can't say I do it everytime either and some plugs can't be undone with the carb on the bike.
