I had an accident a while back, my chain guide dicinegrated after i put on a bigger rear sprocket. My chain came off and went into the case. It doesn't appear to have damaged anything externally. I pulled the clutch cover and right crank case cover off and inspected, also I had to put the shifter back online because it stopped working as well.
I can move my pressure plate freely with the clutch pusher not pushed out. I thought it was my springs. They measured like 36mm and the new ones i got were like 43mm (Something close to).
I can't figure out howcome I don't have enough pressure between the plate and my clutch discs.
perhaps i bent something when i sent my chain into the case? I pulled it all apart into the inner bearing on the hub and i can't see anything wrong.
Any advice or what to do next would be greatly appreciated. I'd like to fix this myself before i take it to a mechanic.
