by crfsonly » Wed Oct 12, 2011 4:11 pm
you'd use a caliper to measure them. also measure the springs.
specs:
drive plates - 2.92-3.08mm
drive plate warp - 0.10mm
spring free length - 38.0mm
check for any notches in the basket or inner hub. also verify the pressure plate is not worn, warped or damaged. check everything from the lever to the clutch for any damage or wear.
crfsonly on Wed Oct 12, 2011 4:24 pm, edited 1 time in total.
