by crfsonly » Mon Sep 12, 2011 7:06 pm
as long as there is nothing else wrong with your carb (which is likely if you've always had this problem) if you are running stock jetting with a hot cam likely your jetting is lean. also, if your accelerator pump us stock you could benefit from doing the AP mod or getting either an adjustable AP cover or the updated Honda AP kit.
