by riddler9 » Mon Mar 18, 2013 11:45 am
take Ken's advice for sure - check EVERYTHING. Washers, nuts, the torex that went missing... At a minimum, everything that you unbolted needs to be checked.
Pull the left cover and the flywheel. Do a visual on the flywheel key, crank sprocket, and screen filter. Something made the noise. If you are sure it was mechanical (clank is mechanical) and not a carb or exhaust sound, stay away from the urge to try it again until the issue is located.
Official Lurker
