Sandpit questions ?
    doggydan
    Sandpit questions ?
    by doggydan » Tue Apr 19, 2005 7:13 pm
    Hey for anybody that has seen a rainbow in a pit or some call it a horseshoe what is the best way to do it and what is the best way to climb a steep hill that has loose sand on it when u dont have much room to gain any speed
    by crfsonly » Fri Apr 22, 2005 11:13 pm
    climbing a hill with out much of a run requires you maintain good traction at the rear which demands throttle control and adjusting your weight to the rear while being careful not to wheelie. you'll have look ahead to locate quickly obstacles in the path to either avoid them or ride through them. look to gain as much momention/speed as possible where ever you can as you move up the hill.
    the only way to get better at climbing hills is to climb lots of them. take them all on and each will teach you something important about climbing.
    good luck,
    Logan#925
    by Logan#925 » Sun Jul 10, 2005 9:52 pm
    I have heard when climbing sand to go at it at an angle and as for the rainbow but it in 2nd go fast straight at really loose sand slid the rear wheel to the beginning of it then pin it and let it keep coming arounbd
