crf 70 oil change advice please
Posted: Mon Nov 05, 2007 4:44 pm
by Jdesey
where is the drain plug
where is the air filter
photos please
Posted: Wed Jan 02, 2008 10:50 pm
by KevinM
If you're still out there...
The air filter is in the black plastic housing under the tank. You open it up a screw driver as I recall. (our 70 is modded so no longer has stock AF).
Drain bolt is underneath case. Bottom of bike. One bolt. No oil filter. Drain it out. Put the bolt back in with a new crush washer and put oil in per manual. Sry... I don't have amount handy.
Your best bet is to order a service manual from the honda dealer. It will tell you everything you need to know. Worth the investment.
