crf 70 oil change advice please
  • Jdesey
    by Jdesey » Mon Nov 05, 2007 4:44 pm
    where is the drain plug
    where is the air filter
    photos please
    KevinM
    by KevinM » Wed Jan 02, 2008 10:50 pm
    If you're still out there...
    The air filter is in the black plastic housing under the tank. You open it up a screw driver as I recall. (our 70 is modded so no longer has stock AF).
    Drain bolt is underneath case. Bottom of bike. One bolt. No oil filter. Drain it out. Put the bolt back in with a new crush washer and put oil in per manual. Sry... I don't have amount handy.
    Your best bet is to order a service manual from the honda dealer. It will tell you everything you need to know. Worth the investment.
    09 CRF 450R
    07 CRF 250R
    FS 2 trns
    05 CRF 250X
