07 crf70f questions
Posted: Mon Sep 24, 2007 11:14 am
by tibs
the air/fuel screw is a d shaped screw.
will this fit it?
http://www.crfsonly.com/catalog/product_info.php/cPath/25_87/products_id/1333?osCsid=42faa18058fd7d0f0ae9a26382b1b2cd
also ive got a fmf powercore exhaust and a uni pod filter.
i cant change my needle settings it doesn't have slots to move the e-clip in.
is there an after market one available?
i live in nor cal around sea level about 70-80 right now. the next size up on my main jet is a 68. stock is a 62 i believe will that be to much gas?
Posted: Wed Apr 30, 2008 10:13 pm
by hobo
If you take a flat head that fits on the flat side of the d just right you can remove it then use a dremel and cut a slot so you can use a flat head screwdriver on it
