by JimDirt » Mon Mar 15, 2021 8:59 pm
I am looking at the diagrams of the 18 , and the 9-11 and 16 , since they are all EFI , what I am seeing is the Black/White seems to go to the ECM that reads Engine Stop Switch , what I would do is test each side of the switch , as the 18 , looks to go directly to ground , but the 09-11 and 16 seems to have the Red/Yellow wire go to a connector that says VCC , not sure what that is , so if you put the Ohm meter on the B/W wire and push the kill button , then put it on the R/Y and push the button , it will either go to negative , or just break the circuit/make the connection open , the R/Y also seems to go to the TP Sensor and the MAP Sensor , and it looks like the MAP Switch ... to me it seems to be a power wire
I really am not sure what would be the best option , but I would think if it went between the R/Y somewhere after the kill button , it would kill the system ... what you might also try is put your meter to Volts , and check the B/W and R/Y when the bike is running to see if it is voltage , then unplug the R/Y and see if the bike dies , it may just be a break in the circuit when the button is pushed , as it could go either way
Question , you said the Tether is supposed to be for a ATV , have you looked at the ATV Manual/Wiring Diagram to see what , if any differences there is between it and the bike ??
