Yeah I guess it can't hurt to soak it and then put it in and let pressurized fuel with Seafoam go throw and try to clear the varnish that may be built up in it.I agree. The right equipment would be ideal for cleaning the injector but it’s better than nothing!
Wouldn’t you think the MIL would pick up a bad oxygen sensor? Again, I’m unfamiliar with these fuel injected bikes. Just seems like something that would throw a code.
The service manual is supposed to be delivered tomorrow so I will have a little bit of time after work to start poking through that. The owners manual mentions to “check ignition timing.” That isn’t something that is commonly out of spec is it?
