cylinder coolant flow
    momuzik
    by momuzik » Mon Feb 12, 2018 10:28 am
    does anyone know the coolant direction through the ports i.e. which ones are incoming and return ports
    Re: cylinder coolant flow
    by Aussiecrf230 » Mon Feb 12, 2018 9:52 pm
    If the hose to the top of the radiator goes to the head and the bottom hose goes to the bottom of the barrel, then flow is from bottom to top. Hence they all flow out of the holes you see in the picture. Either that or if hoses are reveserved the flow is the other way. I believe the first scenario is done with most engines. If it goes top to bottom through the engine they are called reverse flow systems.
    momuzik
    by momuzik » Mon Feb 12, 2018 11:27 pm
    ok thanks Ray..mine is the first you mentioned, bottom to top 😃 thank you
    momuzik
    by momuzik » Tue Feb 13, 2018 12:14 am
    hi Ray one more question..do you know if this channel with little port is a cooling or oil channel (foto) and why does it go into the stud hole?
    by Aussiecrf230 » Tue Feb 13, 2018 3:56 am
    Can you post a picture showing the whole part so I get an overall view.
    Jim Dirt probable knows these motors better so probably reply as well.
    momuzik
    by momuzik » Tue Feb 13, 2018 4:46 am
    ok here you go hope this helps..thanks
    not sure why the little port goes through and is angled drilled into the hole where the stud goes through..is it for coolant or oil im guessing?
    by Back2-2 » Tue Feb 13, 2018 5:22 am
    The long slotted area is for oil flow.
    momuzik
    by momuzik » Tue Feb 13, 2018 8:35 am
    hi neil thanks 😃
    why does it go into the stud hole of the cylinder?
    momuzik
    by momuzik » Tue Feb 13, 2018 8:41 am
    i think i figured it out, must feed into the head..smiles and thanks all
    momuzik
    by momuzik » Tue Feb 13, 2018 8:48 am
    it feeds into the cam bearing assemby
    by Aussiecrf230 » Wed Feb 14, 2018 12:37 am
    I thought it would be oil and the overall view gave the close ups better context.
    Also good you worked some of this out yourself as it helps you understand how your motor works.
    Make sense to use a stud hole as saves having to drill another hole or provide an external oil line. Nice colour on the crank.
    by JimDirt » Thu Feb 15, 2018 11:47 pm
    Sorry Ray , did not get a chance to post because i have been gone since Monday , just got back home tonight , had some Dr. stuff to take care of (nothing major just more fun tests from gastric issues i am still having from the surgery last Sept) .... but you and Neil seemed to have covered everything , and the OP seemed to figure some things out on his own as well , so all is good ..... ;)
    Hopefully , tomorrow i finally get my shock back together that has been sitting on the bench in pieces for the last 5 months since surgery , last weeks CT Scan was all clear for cancer , so far so good , 5 months and counting ...... [-oo , this week was a Colonoscopy AND a Endoscopy at the same time .... talk about a fun time .... :-~ , that was my Valentines Day present to myself (with the help of my Dr's orders ) , got it from both ends , but all the nurses did sign and give me a Valentines Day Card .... :-# :oops: :shock: 8-[
    by Aussiecrf230 » Fri Feb 16, 2018 3:40 am
    Could have been worse Jim, they could have done the colonoscopy first. :?
    Good news about the bigC too.
