05 06 CRF 450R ENGINE SWAP
  • BORMZ
    by BORMZ » Tue Jun 27, 2017 11:03 am
    I have an 05 CRF450r . Will an 06 engine swap out directly?
    Re: 05 06 CRF 450R ENGINE SWAP
    by JimDirt » Wed Jun 28, 2017 7:10 am
    From what i understand , they changed the swingarm mount location on the engine in 06 to tilt the engine down to lower the center of gravity , in doing so , the header was changed and the engine mounts themselves , so i do not believe it would be a "direct" bolt in , basically , the internals of the engine are the same with the exception of a change in cam profile , but the cases have different mounting locations ....hopefully Ken chimes in to confirm .... with that said , i would think if you had the motor mounts and the header from the 06 it should then work , as i believe the frame mounts for the engine are in the same location between the 2 years and only removable engine mounts and engine cases and header were changed ...
  • treyAlejos
    by treyAlejos » Thu Sep 28, 2017 9:16 am
    i have an 05 450r to im tryin to swap my engine what did you do?
  • mxsnow
    by mxsnow » Thu Sep 28, 2017 11:47 am
    I have a 2007 frame with a 2005 motor and an unknown carb,at least that's what the numbers tell me,the 05 motor fits fine.
Users browsing this forum: No registered users and 16 guests
