2004 450r cam shaft bearing removal
    1127kat
    by 1127kat » Fri Jun 26, 2015 4:42 am
    Has anyone changed the bearings on a standard uni cam shaft. I can see that the right hand side bearing would be changeable but the left one is more tricky as the cam sprocket lobes are in the way. Is it possible to press the sprocket lobe off in order to remove the bearing.... rather than changing the whole cam.
  • RDS540
    by RDS540 » Sat Jun 27, 2015 8:19 am
    I just dealt with this on mine. I ended up buying a new cam. I didnt want to press the cam sprocket lobes off and on. It would be to easy to screw up the timing or spin the cam sprocket lobes in the future.
    Just my thoughts, I'm sure other have pressed on/off with no problems
