Suspension Database
    Suspension Database
    by crfsonly » Thu Apr 12, 2007 6:29 am
    Please keep other info out of this thread. Only answer the questions. Copy and paste to keep format uniform.
    Note: Clicker adjustment should be expressed in clicks from full hard.
    Year:
    Rider Weight:
    Rider Weight with Gear:
    Riding Style (i.e. Desert, MX):
    Forks Raised in Triples:
    Rear Tire Size:
    Aftermarket Triples/Offset:
    Fork Springs Wt:
    Fork Spring Brand:
    Fork Oil Amount:
    Fork Oil Brand & Weight:
    Fork Compression:
    Fork Rebound:
    Fork Valving:
    Shock Spring Wt:
    Shock Spring Brand:
    Shock Hi speed Compression:
    Shock Lo speed Compression:
    Shock Rebound:
    Shock Valving:
    Shock Oil:
    Race Sag:
    Preload:
    by [email protected] » Thu May 24, 2007 7:40 am
    Year: 07 450R
    Rider Weight: 258
    Rider Weight with Gear: 273
    Riding Style (i.e. Desert, MX): Off-Road,MX
    Forks Raised in Triples: Flush
    Rear Tire Size: 19"/110
    Aftermarket Triples/Offset: BRP 22mm
    Fork Springs Wt: .49
    Fork Spring Brand: Factory Connection
    Fork Oil Amount: 12.0 oz.
    Fork Oil Brand & Weight: Race Tech Ultra Slick 5Wt.
    Fork Compression: 9
    Fork Rebound: 11
    Fork Valving: Stock
    Shock Spring Wt: 6.0
    Shock Spring Brand: Eibach
    Shock Hi speed Compression: 2 turns out plus line up dot
    Shock Lo speed Compression: 11 clicks out plus line up dot
    Shock Rebound: 7 turns out plus line up dot.
    Shock Valving: Stock
    Shock Oil: Race Tech Ultra Slick 5wt.
    Race Sag: 3.9"
    Preload: 2.0"
    For motocross what has worked is taking these settings and increasing everything two clicks stiffer except for high speed, which stays how it is.
  • PaiNLeSS
    by PaiNLeSS » Thu Nov 22, 2007 6:58 pm
    Year: 2005
    Rider Weight: 170
    Rider Weight with Gear: 180
    Riding Style (i.e. Desert, MX): MX
    Forks Raised in Triples: 0.00
    Rear Tire Size: Stock
    Aftermarket Triples/Offset: Stock
    Fork Springs Wt: 0.49
    Fork Spring Brand: Rce Tech
    Fork Oil Amount: 340cc
    Fork Oil Brand & Weight: Amsoil 5wt
    Fork Compression: 10
    Fork Rebound: 9
    Fork Valving: revalved (12)30X.10, 20X.10, 30X.15, stock from there down, stock mid & rebound
    Shock Spring Wt: 5.3
    Shock Lo speed Compression: 10
    Shock Rebound: 9
    Shock Oil: 2.5wt
    Race Sag: 103mm
    Preload: 10 ( I think )
