2006 crf150 hop ups?
  • gmrviper
    by gmrviper » Mon Jul 17, 2006 6:12 pm
    well i got a crf last week and im kinda bummin cause im not seeing many little hop ups for it. seems like its all for the 05 and back. does anyone know if there is a rev box for it yet? and mainly a power up kit or somesort of jet kit. i did get a k@n filter for it and i figured id take the baffle out . thanks for tha help
    by Asmith » Mon Jul 17, 2006 7:45 pm
    All mods for the 05 and back will work on the 06.
    Only change made in the 06 model is the electric start.
  • gmrviper
    by gmrviper » Tue Jul 18, 2006 11:18 am
    huh everybody that ive called on a rev box has told me they are different............thanks for the info though.......maybe im talkin to the wrong people
    by Asmith » Tue Jul 18, 2006 3:31 pm
    Because the 06 has an electric start and a charging system the rev may be different for the 06.
    The rev box is the worst place to spend money. It does very little to nothing at all.
    Open your airbox - free
    Change to a better filter - $20.00
    Power up or JD jetting kit - $ 60.00
    Remove exhaust baffle - free
    or
    Aftermarket Exhaust -$ 250.00
    Start spending on these items first, you'll get the biggest bang for the buck here.
  • gmrviper
    by gmrviper » Wed Jul 19, 2006 11:32 am
    thats good advice i appreciate it
  • dk54red
    by dk54red » Sun Jul 23, 2006 5:25 pm
    I have a 06 and there are pleanty of mods to do, but most of them are not cheap. One that I haven't seen in this tread is get rid of the stock tires. If you do the mods mentioned by ~ and maybe gear up the back 1-2 teeth it should help some. Depending on your weight look at getting stiffer springs. I got a tip from ebeck about installing a battery charger plug with a cap and it makes it nice not having to take out the battery all the time. don't leave the key on or the batt. will die
    If you want more, then call engines only. I have the 225 kit in mine and it rips. I have the cr85 front end and I have just ordered the works shock for the rear and a Barnett clutch. I know it will be a stable and fast ride.
    by Asmith » Sun Jul 23, 2006 5:28 pm
    dk54red wrote:I have a 06 and there are pleanty of mods to do, but most of them are not cheap. One that I haven't seen in this tread is get rid of the stock tires. If you do the mods mentioned by ~ and maybe gear up the back 1-2 teeth it should help some. Depending on your weight look at getting stiffer springs. I got a tip from ebeck about installing a battery charger plug with a cap and it makes it nice not having to take out the battery all the time. don't leave the key on or the batt. will die
    Welcome to CRF's!!!! Nice to have you here.
    I agree with the battery charger. Ken sells the kits here to install the permanent leads. I think they are Yuasa.
    Now we need to get Ebeck over here and off of that other site.
  • dk54red
    by dk54red » Sun Jul 23, 2006 5:42 pm
    Thanks, your the one who mentioned it, so I checked it out. Ebeck and you have made a difference in my choices. I am out for two months. Just had shoulder surgery, time to order parts and break out the tooth brush and give her a good cleaning. I am regreasing almost anything I can.
    DaJumper
    by DaJumper » Mon Jul 24, 2006 6:10 am
    Hey yall.. about the front forks for the CRF 150.... go to www.regerengineering.com they have front forks that can still mount the dual piston caliper from ur 150 rather than the single piston caliper from the 85,,, and its all their no lookin around for other needed things
    Crf150-STOLEN
    crf100-STOLEN
    DR350-STOLEN
    by Asmith » Mon Jul 24, 2006 6:18 am
    DaJumper wrote:Hey yall.. about the front forks for the CRF 150.... go to www.regerengineering.com they have front forks that can still mount the dual piston caliper from ur 150 rather than the single piston caliper from the 85,,, and its all their no lookin around for other needed things
    We both have the CR85 conversions already done. I'm not sure what your statement is regarding as there are no questions about it in this thread.
