Jetting for CRF150F
  • willflyforfood
    Jetting for CRF150F
    by willflyforfood » Fri Oct 22, 2004 4:57 pm
    What is the stock size for the main jet? My Honda dealer wasn't sure. I hope it's not 110, they didn't have a 115 in stock so they gave me a 110. I just installed a Twin Air Filter and a Big Gun exhaust, do I need to replace the needle or can I just reposition the clip on the stock one.
  • CRFrider04
    by CRFrider04 » Sat Oct 23, 2004 5:36 pm
    The stock main jet size is 115
    Also, i have a question for ya...Did the Big Gun exhaust give you alot more power? Im curious cuz im looking at one for myself.
  • willflyforfood
    by willflyforfood » Sat Oct 23, 2004 6:37 pm
    The stock main jet is 98, not sure if I got more power, haven't gone riding yet. Too damn cold in BC. It sure does look good though!!!! Next I am going to lighten my flywheel. The local machine shop will do it for beer.
  • Guest
    by Guest » Sun Oct 24, 2004 6:03 am
    is it really 98? i was told it was 115 or SHOULD be 115, sorry about the wrong info :oops:
  • macattack
    Jetting for CRF150F
    by macattack » Fri Nov 05, 2004 2:24 pm
    Stock jetting is 98, 115 is what Big Gun recommends for their pipe. Big Guns' 'Needle Recommendation' is 16012-KPS-921, and they say to remove the intake restrictor.
  • CRFrider04
    by CRFrider04 » Sat Nov 06, 2004 7:43 am
    -The intake restrictor is a little snorkle type rectangle at the top of the air box, You have to push up on the rectangle and it should pop out. Then loosen the airbox bolts to get it out from under the seat.
  • willflyforfood
    by willflyforfood » Sat Nov 06, 2004 9:52 am
    Thanks for all the info guys, I have already removed the snorkel, that was one of the first things I did when I got the bike. I also removed the spark arrestor screen. The 110 jet is fine I checked my plug on a ride after I did the mods and it looks good, dark brown almost black. I moved the needle clip down one position on the stock needle, the bike runs well, good throttle response so I don't need that other needle.
    Cheers.
