neutral switch
  • bweighmaster
    neutral switch
    by bweighmaster » Wed Oct 18, 2017 7:05 am
    07 crf150f where is neutral switch how do i delete it ????
    Re: neutral switch
    by Back2-2 » Wed Oct 18, 2017 1:09 pm
    I will just take a stab here and see if I can aim you in the right direction. Not knowing exactly what you are try to achieve.
    The neutral switch [ if there is one ] will be either on the underside of the engine case or on the left side above the shifting shaft. One wire switch. There will more than likely a safety switch in the clutch lever mechanism also. There can also be a safety switch on the kick stand. Hope that gives you some direction of where to look depending on what you want to do. All are easy close loop to buy pass systems.
