Drain Gas
Posted: Thu Oct 27, 2005 2:08 pm
by Hondacrf150F3
It there an easy way to drain the gas? Because I want to run 110 in it thanks.
Posted: Thu Oct 27, 2005 2:35 pm
by PGer555
run it dry then put in your 110. Its the easiest way plus ull be wasting alot of gas which equals money!
Posted: Thu Oct 27, 2005 6:30 pm
by oldtimer
If you must drain it just remove the tube going to the carb behind your shutoff valve, in the off position, then attach a piece of tubing to where you removed the fuel line into a gas can and turn it back on.
You must have some serious motor work done? Is your piston up at 11 or 12 to 1 compression ratio?
If not you are completely wasting your money on 110. Or anything-over 92 or 94 pump gas.
Posted: Fri Oct 28, 2005 5:07 am
by Hondacrf150F3
Ya I am not going to now my dad said it could do some damage to the pistion so I will just stick with the 93 since that is what I have always ran in it thanks.
