Drain Gas
    Hondacrf150F3
    Drain Gas
    by Hondacrf150F3 » Thu Oct 27, 2005 2:08 pm
    It there an easy way to drain the gas? Because I want to run 110 in it thanks.
    PGer555
    by PGer555 » Thu Oct 27, 2005 2:35 pm
    run it dry then put in your 110. Its the easiest way plus ull be wasting alot of gas which equals money!
    oldtimer
    by oldtimer » Thu Oct 27, 2005 6:30 pm
    If you must drain it just remove the tube going to the carb behind your shutoff valve, in the off position, then attach a piece of tubing to where you removed the fuel line into a gas can and turn it back on.
    You must have some serious motor work done? Is your piston up at 11 or 12 to 1 compression ratio?
    If not you are completely wasting your money on 110. Or anything-over 92 or 94 pump gas.
    06 CRF80
    04 CRF70
    88 CR250
    Hondacrf150F3
    by Hondacrf150F3 » Fri Oct 28, 2005 5:07 am
    Ya I am not going to now my dad said it could do some damage to the pistion so I will just stick with the 93 since that is what I have always ran in it thanks.
