Hard to start when hot.
  • 737Captain
    by 737Captain » Sun Aug 14, 2005 1:40 am
    We're new to this great world of four stroke dirt biking. Just bought three new CRF's; 100 - 150 - 230. The kick start bikes seem pretty tough to restart when they are warmed up. Especially the 150. I turned up the idle speed a touch, but otherwise they are totally stock. Probably de-baffle and rejet when the kids get a little more seat time. Any tips on starting these terrific bikes when we're out riding?
    Thanks,
    Ed
    2005 CRF 100
    2005 CRF 150
    2005 CRF 230
    2004 CRF 250X
    1997 KDX 220R
    by crfsonly » Sun Aug 14, 2005 4:20 pm
    welcome 737 captain. a warm 4-stroke starts better on a lean mixture. therefore, don't use the choke, and make sure you aren't using any throttle as this will richen the mixture. also, a steady and firm kick works much better than a hard and fast kick.
    lastly, a free flowing air filter and proper jetting will help with starting.
    good luck...ken
  • Joker7Icp
    by Joker7Icp » Tue Aug 30, 2005 7:35 pm
    What??? no choke I only 13 and I couldnt start mine at all.. then I put the choke on and it starts up 1st or 2nd kick.. should I not do that??
    I got a CRF 150
    by crfsonly » Tue Aug 30, 2005 9:38 pm
    if your engine is cold then the choke helps a lot...if it's warm/hot then the choke will make it harder to start as it richens the mixture. it won't damage the bike by using the choke it just makes it harder to start if its already hot.
    DaJumper
    by DaJumper » Thu Sep 22, 2005 7:48 pm
    Im not so sher but once i got the a new muffler and rejeted the carb i never ever had any problems starting up my 150 hot or cold. so if you want to you could try what i did i'd highly recomend it expecially if you wand some more power to.
    Crf150-STOLEN
    crf100-STOLEN
    DR350-STOLEN
    DrtBkeRyder4
    by DrtBkeRyder4 » Mon Oct 17, 2005 11:59 pm
    my bike starts 1st-2nd kick without much to any force
    - Go Fast Or Go Home -
    ..::If You Never Fall Off Your Not Riding Hard Enough::..
    '03 Crf150f
  • CRFrider04
    by CRFrider04 » Wed Oct 19, 2005 5:54 am
    I dont understand why so many people are having trouble starting their 150's. When i start it i just turn on the gas, pump it a few times, turn on choke and it starts on the first or second kick everytime. When its hot it starts right away first kick no problem, sometimes i have to start full throttle though.
    Also, im having no difficulty while my bike isnt even properly jetted, i have the snorkle out, and the baffle out and it still starts fine. I do have a 110 main coming my way.
    What size pilot jet should i have? do i need a pilot jet if i get new main jet?
    PGer555
    by PGer555 » Wed Oct 19, 2005 11:57 am
    a 42 pilot should do the trick for you. The pilot jet gives you better off the line throttle response while the main jet controls more in the higher rpm's
  • FATOPU
    by FATOPU » Fri Nov 25, 2005 12:51 pm
    OK MY WIFES CRF150 HAS ALLWAYS BEEN HARD TO START, TAKES FOR EVER TO WARM UP. THEN SEEMS A LITTLE BETTER WHEN WARM BUT SOMETIME SHE STILL HAS A HARD TIME. HAD PROBLEMS STK THEN DID THE POWER UP KIT, SNORKEL REMOVED, BIG GUN REV BOX, BIG GUN EXHAUST, UNI FILTER, 115MAIN, 38 PILOT AND NEEDLE IN 4TH CLIP FROM THE TOP. FEELS OK WHEN WARM NO BACKFIRE ON DECELL, BUT ALITTLE POP AT AN IDLE. FEELS SMOOTH ON ACCEL? BUT STILL HARD TO START, AND SHES BEEN RIDDING IT FOR TWO YEARS AND HAD A XR200 BEFORE THAT. WHAT DO YOU GUYS THINK, I'AM LOOKING AT A CRF230 WITH AN ELECTRIC START, SHE WANTS MORE POWER AND I JUST CANT GET ANY MORE OUT OF THE 150
  • FATOPU
    by FATOPU » Tue Nov 29, 2005 7:16 pm
    Well its been a few days since my last post, and looks like no one else is interested in this post but me, so I have been trying to find the right combination on my own, its amazing that no one else is posting anything about the specs of jetting on this bike, not even the big exhaust manufatures. most of them say to use the stk settings, but I couldnt find what stk was? This is what seems to be working for me, main #108, pilot #38, stk needle in 3 position, air bleed 2-1/2 turns out from in, I think the air bleed was the biggest adjustment that made it easier to start. I tried the #40 pilot everyone talks about but the #38 seems to be the best at 2-1/2 turns out. its a girls bike and if its a little lean I think it will be ok, at least she can start it on her own. Hope this helps someone? Idle is smooth, no coughing, and I did install the stk pipe back on it.
Users browsing this forum: No registered users and 11 guests
