Softer Shock Spring
  • rurman
    Softer Shock Spring
    by rurman » Tue Aug 05, 2008 9:05 am
    I'm looking for a softer shock spring for the 150F. Does anyone make a spring appropriate for a 100 lb. rider?
    Ron
  • Collin
    Softer spring?
    by Collin » Thu Aug 07, 2008 6:32 pm
    No, most of us find the stock spring too soft. I weigh about 104 lbs. Way too much sag in the rear end with the stock spring wound down tight. I went to BBR Springs. They are just a little stiff, with the tension backed all the way off. I really like them when jumping, I don't bottom out everytime. I have a well worn original spring out of a 2003 150F that you could have, but I can assure you won't be happy.
