by '04crf150f » Mon Jul 18, 2005 8:37 pm
the only thing i have to say is it has to be broke in, like a horse difficult to get to go for a while to you and the horse are use to each other, i've had mine since the '04 christmas and now i can start it with at the most two or maybe three kicks, if you do get it to start and when you do at full choke, switch it into half quickly, and let it sit without revving it, revving only puts gas in the carb when it's still cold so it takes longer to ignite and it chokes down and floods, if you do flood it sitting on the ground or after a crash hold the bike by the bar lay it down until the peg touches the ground then stand it back up and try again, this lets the excess gas in the carb drain
Chase Cullinan
