want more power
  • dirtbikerliker
    want more power
    by dirtbikerliker » Sun Mar 16, 2008 8:15 pm
    hey guys. i want to get more power out of my bike. i already took the snorkel out of my air filter, and took out the exhaust baffeling. i know a pipe would give me more power, but i hear that its a waste of money if its being put on a 150f. is there anything else i could do to get more power/better response. your input is much appreciated. i also dont have a lot of money( just to let you guys kno)
    Tony
    by Asmith » Sun Mar 16, 2008 8:20 pm
    Did you rejet after making your bike REALLY lean now?
  • dirtbikerliker
    by dirtbikerliker » Sun Mar 16, 2008 8:30 pm
    no. but my dads friend. whos been riding for 25 yrs, and has had 3 crf150fs, and my uncle also said, that it wont make to much of a dif. does it make much power difference?
    by Asmith » Sun Mar 16, 2008 8:38 pm
    Power is made by mixing fuel and air and compressing it, then igniting it.
    The changes you made let more air in and more exhaust out. More air, without more fuel does nothing but make your bike run leaner and hotter.
    Rejetting calibrates the correct amount of fuel to use with the new amount of air you are letting in.
    More air + More Fuel = More power.
  • dirtbikerliker
    by dirtbikerliker » Sun Mar 16, 2008 8:58 pm
    ok. i get what ur saying. so it if i were to move the ring on the main needle in the carb up/down a noth(i forget which way it is), that wouldnt do ne thing? but jetting it does wut exactly? larger holes allowing more gas flow?
    by Asmith » Sun Mar 16, 2008 9:05 pm
    99103-KPT-0420-Slow jet (42 being the size, stock is 40)
    -99113-GHB-1150-Main jet (115 being the size, stock is 98 )
    Now you can change the needle , but you really don't have to change it just move the clip to the fourth notch from the top of the needle if it isn't already there at the fourth notch.
    If you do want to change the needle use part number -16012-KPT-921-Needle set (on the middle clip) .
  • dirtbikerliker
    by dirtbikerliker » Sun Mar 16, 2008 9:08 pm
    umm. when i bought the bike. i took apart the carb and moved it to the middle clip. cuz the kid i bought it off of said thats where it originally was before he moved it. so. the clip is on the middle slot. ok. i gotcha. so once i rejett it, i should see significant power dif./ response
  • dirtbikerliker
    by dirtbikerliker » Sun Mar 16, 2008 9:15 pm
    wait. so just get a size 42 slow jet and size 115 main jet. and then im good?
    by Asmith » Sun Mar 16, 2008 9:20 pm
    dirtbikerliker wrote:wait. so just get a size 42 slow jet and size 115 main jet. and then im good?
    And bump the clip down one notch on the needle.
    by [email protected] » Sun Mar 16, 2008 9:25 pm
    I've got an idea :idea:
    Why not read AS's very specific advice where he told you the exactly the Honda part number, the exact size and exact type of jet, and where exactly to put the needle clip ?
    Yes, you'll get a little more power and a lot better throttle response, and a lot easier starting and a lot cooler running.
    It's a 150,and it'll run as good as it's going to.
    Leave it how it is and risky burying your motor at a young age. Your dads friend is wrong. Doug
  • dirtbikerliker
    by dirtbikerliker » Mon Mar 17, 2008 12:42 pm
    hey guys. i have another question. wut if i were to buy a 15 tooth sproket for the front and i think its like a 50 tooth for the back. cant quite remember. wud that do anything substantionally dif, and i would need to get a new chain too huh?
  • dirtbikerliker
    by dirtbikerliker » Mon Mar 17, 2008 5:48 pm
    hey guys. where would i get those jets. i couldnt seem to find them on the crfsonly website. where do i order them from?
    by [email protected] » Mon Mar 17, 2008 6:03 pm
    those jets
    Are at the dealer. He gave you Honda part numbers.
    Do that and don't worry about the rear , it's fine as it is when you run the 15T front.
    No.
    Hey, I have to ask you....are you stoned or something ? We have given you very ,very clear advise , directions, part numbers but it's like nothing is soaking in.
    If you want help here we are glad to do so, it's what we do.
    However, if you're all over the board with your questions (You sure are), and disregard or skim read what we are taking the time to post in order to help you(You must be) you're going to find your future questions falling on deaf ears.
    Lastly, while this isn't english class a little more care in your spelling and punctuation would sure make your posts easier to read.
    Others are giving you properly spelled,easy to read answers, how about extending the same courtesy ? Doug
  • dirtbikerliker
    by dirtbikerliker » Tue Mar 18, 2008 8:12 am
    sorry if my spelling hasn't been top notch doug, but im just getting over being sick. and im not stoned. i don't do that. im not retarded. my drug is dirtbiking. and swimming. so. sorry if i've been asking dumb questions but im a newbie. what am i supposed to do?!!? i just want to know. that way i can become as knowledgeable as you guys are someday. so. sorry for asking dumb questions and for all my spelling errors. i hope this reply is much easier to read. thanks for all your help. im going to order some new jets soon and probably a new front sproket. thanks again. have a good one.
    Tony
    by [email protected] » Tue Mar 18, 2008 2:00 pm
    Glad to have you Tony,
    Let us know how we can help. You are going to be tickled pink with your bike when you get those things done. Doug
