2009 Manual for 2015
  • FilthyPlumber
    by FilthyPlumber » Sat May 11, 2019 8:45 am
    Hey all,
    Just noticed the owners manual I was given when I bought by 2015 CRF230F is for a 2009. From what I’ve been reading, just about everything is the same but haven’t been able to make a definitive decision. Will the 2009 manual suffice for my 2015 or have things like oil requirements and part numbers changed?
    Livermore, CA
    2015 CRF230F
    86'd snorkel
    FMF PowerCore 4
    +600-2400'
    40-95*F
    45 pilot
    132 main
    Clip in 4th position
    Featherweight lithium battery
    Re: 2009 Manual for 2015
    by JimDirt » Sun May 12, 2019 7:46 am
    Ray would be the CRF230 expert around here , hopefully he will chime in with a answer , the only Manuals I have for them is for the 02 and 07 , both Owners Manuals , so they would not give me enough info to give a definitive answer of what has changed over the years ... :cry:
    by Aussiecrf230 » Sun May 12, 2019 3:11 pm
    Hi FilthyPlumber,
    Not much changed over the years except the carb needle with less clip positions.
    They're a solid bike to start with and have proven old school technology.
    See that your jetting has been changed which needle are you using?
    As far as lubing goes use a good quality oil and change when appropriate.
    Use a waterproof grease on head bearings, swingarm and linkage. They are often undergreased from the factory and not waterproof.
    Part numbers change often with bikes, it still maybe the same part but from a different supplier or when superceded or small change is made. Check the Yeltrik site for part numbers.
    http://partsfinder.onlinemicrofiche.com ... finder.htm
  • FilthyPlumber
    by FilthyPlumber » Mon May 13, 2019 4:26 am
    Hi FilthyPlumber,
    Using the CRFsonly power up needle in the 4th position.
    Thanks for the info! I'm on the hunt for a service manual as well so between those two things I'll be covered. I have heavy duty waterproof grease for my boat so I think that'll work for the bike as well. 👍
    Livermore, CA
    2015 CRF230F
    86'd snorkel
    FMF PowerCore 4
    +600-2400'
    40-95*F
    45 pilot
    132 main
    by Aussiecrf230 » Mon May 13, 2019 6:25 am
    The service manuals like the owners manuals only get updated if they change something. I wouldn't be surprised if the last change was 2009. Really depends if they rolled the 230L into the same manual as they are different creatures being more road orientated.
    Have fun - that's what these bikes do best.
