Posted: Sun Jan 12, 2014 6:55 pm
by JD
Does anyone know if the 2005 screw set part #16016-393-700 will replace the "D" screw from a 2006?
Posted: Sun Jan 12, 2014 7:02 pm
rather than get a stock fuel screw replace it with our t-handle fuel screw. this will allow you to adjust it without tools:
http://www.crfsonly.com/catalog/product ... ts_id/1362
Posted: Sun Jan 12, 2014 7:10 pm
by JD
That sounds like a better replacement part ! Thanks Ken
Posted: Sun Jan 12, 2014 7:14 pm
you're welcome. if you have d-shape fuel screw you can use an electrical butt connector to remove it. heat up one end of the connector, slide it over the d-shape screw and let it cool. instant removal tool.
Posted: Fri Jan 31, 2014 8:30 am
by firsthere
crfsonly wrote:you're welcome. if you have d-shape fuel screw you can use an electrical butt connector to remove it. heat up one end of the connector, slide it over the d-shape screw and let it cool. instant removal tool.
Excellent idea, I plan to give that a try.
Posted: Fri Jan 31, 2014 8:36 am
by JD
What gauge size wire connector butt would I need to get?
Posted: Fri Jan 31, 2014 1:48 pm
going from memory 18 gauge.
Posted: Sat Feb 01, 2014 8:04 am
by firsthere
Yeah, tried 14-16 gauge and it seemed to large.
Posted: Sat Oct 24, 2015 3:25 pm
by hwlake
I installed a t handle fuel screw...my only issue is that the t bottoms out on the carb bowl before the threads do. do yourself a favor and grind approx 3/16 off of each side of the T before installing it so that you can bottom it out and turn out to set the proper mix.
