Fuel Screw
  • JD
    by JD » Sun Jan 12, 2014 6:55 pm
    Does anyone know if the 2005 screw set part #16016-393-700 will replace the "D" screw from a 2006?
    by crfsonly » Sun Jan 12, 2014 7:02 pm
    rather than get a stock fuel screw replace it with our t-handle fuel screw. this will allow you to adjust it without tools:
    http://www.crfsonly.com/catalog/product ... ts_id/1362
  • JD
    by JD » Sun Jan 12, 2014 7:10 pm
    That sounds like a better replacement part ! Thanks Ken
    by crfsonly » Sun Jan 12, 2014 7:14 pm
    you're welcome. if you have d-shape fuel screw you can use an electrical butt connector to remove it. heat up one end of the connector, slide it over the d-shape screw and let it cool. instant removal tool.
  • firsthere
    by firsthere » Fri Jan 31, 2014 8:30 am
    crfsonly wrote:you're welcome. if you have d-shape fuel screw you can use an electrical butt connector to remove it. heat up one end of the connector, slide it over the d-shape screw and let it cool. instant removal tool.
    Excellent idea, I plan to give that a try. :D
  • JD
    by JD » Fri Jan 31, 2014 8:36 am
    What gauge size wire connector butt would I need to get?
    by crfsonly » Fri Jan 31, 2014 1:48 pm
    going from memory 18 gauge.
  • firsthere
    by firsthere » Sat Feb 01, 2014 8:04 am
    Yeah, tried 14-16 gauge and it seemed to large.
  • hwlake
    by hwlake » Sat Oct 24, 2015 3:25 pm
    I installed a t handle fuel screw...my only issue is that the t bottoms out on the carb bowl before the threads do. do yourself a favor and grind approx 3/16 off of each side of the T before installing it so that you can bottom it out and turn out to set the proper mix.
