06 crf jetting (WHATS THIS FOR?)
  • tomcatrzr09
    by tomcatrzr09 » Fri Jan 11, 2013 5:29 pm
    Hi Ken, got the power up kit for a 06 crf230 how does the spacer for the needle go on? keep lookin at it but doesnt seem right. is the needle suppose to slide into the spacer? it stops when it gets to the end of the taper. doesnt look like it goes between the spring and the needle either. picture of how it goes on would be great. thanks a ton!
  • staffy24
    by staffy24 » Fri Jan 11, 2013 5:30 pm
    under the circlip
    over 40 still ridin hard
    still learning
    by crfsonly » Fri Jan 11, 2013 6:05 pm
    this is the needle seat (the "spacer" as you refer to it) and it is not necessary to remove or replace it when changing needles unless yours is damaged or warn.
  • tomcatrzr09
    by tomcatrzr09 » Fri Jan 11, 2013 7:58 pm
    There was not one on it (spacer). it has a spring and a linkage setup with two screws to hold a plate on it.so the spacer slides up the needle and seats at where the tapered cut stops? seems like the needle wont go down far enough compared to where it was originally by doing it that way. let me know if im thinkin wrong.thanks!
    by crfsonly » Fri Jan 11, 2013 8:13 pm
    you don't need the seat...just replace the needle. use the middle clip position. put it in just as the stock needle was installed.
  • tomcatrzr09
    by tomcatrzr09 » Fri Jan 11, 2013 8:20 pm
    THANK YOU! I was a little confused there. gonna have the boy put it back together tomarrow.he needs to learn how this works. once again thank you.
