Here 'ya go check these links out. Stock 42 pilot is too small that off-road.com uses. Might be OK for older models... Ken has a kit with a 45 pilot. The fuel screw works in conjunction with the pilot for adjusting fuel mixture from idle to 1/4 throttle. It is located in front of the float bowl in a recessed area. '07 has a "D" shape and you need a special tool to adjust the setting. You can get one from motion pro if you want to go that way. The after market - like the Kouba sold here allows you to adjust or tweak it without a tool. If you do change the fuel screw out, make sure you don't lose the spring, washer and small o-ring. Parts easy to lose. I put a towel under whole area to catch the parts. Also a little lube when re-assembly on the o-ring - like a little bit of vaseline is a good idea. Don't tighten the screw real tight either. You'll crush the o-ring. Don't ask me how I know this
I heard it from someone else - yeah that's right - that's my story and I'm stickin' to it.
To get to the main jet needle you have to unscrew the cap off the top of the carburetor etc.
Links below have step by step and some pictures.
http://dirtbike.off-road.com/dirtbike/Project+CRF230F/Project-Honda-CRF230F---Part-1/ArticleStandard/Article/detail/380749?contextCategoryId=24439
I left the push pull cables on the carb. At least for now.
http://rickramsey.net/CRF230Fcarb.htm
You don't need the "swinger" tool. Just twist the throttle to raise the slide.
