07 230 fuel screw baseline
    NCLR1
    by NCLR1 » Sat Dec 20, 2008 12:37 am
    I did the hop up mods on my brother's 07 230F today. I had a real bear with the fuel screw. I am not sure wether or not I started at flush and went out or not. It went in approx.. 3/4 to 1 full turn. Then I just backed it out 1 and 1/2 turns. Just wanted to know if anyone else could remember what their fuel screw was set at initially prior to adjusting it? Thanks.
    Tony C
  • tomvcrc
    by tomvcrc » Sun Dec 21, 2008 10:32 am
    5/8th of a turn is stock. It sounds like you didn't have a D socket to turn the screw? This little socket helps out a lot if you don't have one of the aftermarket fuel screws installed. Your safe with 1 1/2 turns out and the power up kit installed. Check the plug after a half hour of riding. Too black-start turning in the screw.
    NCLR1
    by NCLR1 » Mon Dec 22, 2008 6:50 am
    Thanks
    Tony C
