Hondacrazi wrote:Ok, the 230 stock has about 23 hp. the 250 only has 35 stock. With taking out the baffle, getting a better air cleaner, and opening up the airbox you can get 5 horses. If you want a little more, you can mix it with e85 ethanol, not a lot and get about 2 more. When you open the airbox and exhaust, make sure you rejet it. The pilot jet is fine most of the time, just change the main jet.
~ wrote:Hondacrazi wrote:I had my bike dynoed. It dynoed out at about 23 horses.
If you think that a stock 230 makes 23 HP you are high as a kite.
It would take Alot of money to get to 23 hp including a ton of parts from Coeshow.
