massivemassey wrote:UPDATE:: installed the 132/45 combo with power up needle, opened up air box, replaced filter with twin air filter, removed exhaust baffle and adjusted fuel screw. bike runs great after adjusting the fuel screw just right. warms up quicker and can pop the front end up alittle easier now.
the spark plug is clean but i need to take the bike out this weekend and really ride it and then check the plug again and see, from what i can tell the plug is clean, no lean looking deposits and definately not dark/burned looking. a few other guys i work with told me it looks really good so i guess i will find out how well after my first ride this coming weekend.
thanks to everyone for your help.
carters2 wrote:massivemassey wrote:UPDATE:: installed the 132/45 combo with power up needle, opened up air box, replaced filter with twin air filter, removed exhaust baffle and adjusted fuel screw. bike runs great after adjusting the fuel screw just right. warms up quicker and can pop the front end up alittle easier now.
What clip position you using on the power up needle?
Actually it's not unless it's very little , it means you're still a little lean and your pilot needs opened a little.the exhaust would pop a little everynow and then, but i also found out this is normal with an opened up exhaust
