CRF230RiPPER wrote: But I also hear mixed things about the valve wear with this bike. Anyone have any experience with this?
~ wrote:CRF230RiPPER wrote: But I also hear mixed things about the valve wear with this bike. Anyone have any experience with this?
If you heard that this bike has issues with valve wear then you were listening to a moron. (Or they got it mixed up with the 250's.)
The valve wear on the 230 is Glacial. They will get tens of thousands of miles without any issue.
Checking them is easy, alot easier than the 250/450.
Adjusting them is also easier.
Something that you should learn to do yourself, but certainly not something that you should worry about.
gal8x wrote:In general; the most common mistake I see young mechanics make is they have a tendency to over tighten nuts and bolts. They notice that the bolt/nut was very tight, so they assume that it must be put back on that way. Not so. Nuts/bolts will tighten themselves thru heat and vibration. You don’t need a toque wrench for this job but when you read the manual pay attention to them anyway and you will notice the values are low, 11 lbf to 4.3 lbf that equates to “snug, plus a little”
postaldave wrote: does the standard owners manual cover valve adjustments or do you need a shop manual?
CRF230RiPPER wrote: Any suggestions on getting that bolt out on my clutch perch???
Aussiecrf230 wrote:gal8x,
I thought that was strip and back around a turn.
