Rejet?
  • dirtbikepro64
    Rejet?
    by dirtbikepro64 » Mon Jul 16, 2007 1:40 pm
    If i were to drill holes in my baffel as mentioned in http://www.rickramsey.net/CRF230Fmods.htm and not take out the snorkle, do you think i would have to rejet? it is not that big of a change in back pressure.
    Josh
    K&N Air Filter
    Renthal 428 Conversion Kit
    BBR 1/2 inch longer Shift lever
    BBR Rev Box
    Tusk Clutch Kit
    gal8x
    by gal8x » Mon Jul 16, 2007 4:47 pm
    "I also removed the air box intake baffle. After the baffle exercise, I went up one on the main jet, and the plug is nicely tan colored."
    Why reinvent the wheel? Round works.
    Rick Ramsey pulled the snorkel and rejected. You should too.
  • dirtbikepro64
    by dirtbikepro64 » Tue Jul 17, 2007 9:30 am
    yeah but ive messed with jetting once and if i pull the snorkle and drill holes in the baffel and then the rejet doesnt work right then thiers no going back. Besides does it make that big of a difference?
    p.s whats the main jet in it now? thanks
    Josh
    K&N Air Filter
    BBR Rev Box
    Tusk Clutch Kit
    gal8x
    by gal8x » Tue Jul 17, 2007 5:20 pm
    You can always go back.
    A new arrester assy is $90, more than I would pay. But there are a lot of people who may still have the ones that they removed. You should be able to find one for under $30, mine wound up in Thailand! :shock:
    A proper power-up mod requires you to remove the snorkel and the baffle and the power-up kit from Honda. You will get a substantial power gain. The downside is the bike will be equally louder. Not as bad as a 2 stroke but definitely enough your neighbors will know when you are ridding. Pro Circuit makes a pipe that will do the job but I have no experience with it.
    If you want power and low noise then you are going to spend some money.
    I ride along a creek that borders four subdivisions. All I do is go easy when I am close. Once I hit the trees its balls-out. I have no troubles with the neighbors.
  • dirtbikepro64
    by dirtbikepro64 » Wed Jul 18, 2007 12:28 pm
    If i did this and added that needle, which nothch should i put it on and what is the brass tube like thing tht comes with it?
    Josh
    K&N Air Filter
    BBR Rev Box
    Tusk Clutch Kit
    gal8x
    by gal8x » Wed Jul 18, 2007 6:19 pm
    More than likely the middle position, it depends, I cant say for Michigan. Ask your Honda dealer.
    That brass thing is the needle seat. It is the same as the stock one. If yours is not damaged then keep the new one as a spare.
