by crfsonly » Mon Jun 18, 2007 6:57 pm
you can clean the air filter until it starts to wear/tear. make sure you oil it after cleaning with a quality air filter oil. on the springs, the aftermarket springs are only necessary if you are heavier than the designed weight from the factory...usually about 165-180lbs.
