CRF230F Suspension
  • LR_198
    CRF230F Suspension
    by LR_198 » Sat Apr 28, 2007 9:20 am
    Can someone please give me step by step instructions on tightening my back suspension?
    kawiridr04
    by kawiridr04 » Sat Apr 28, 2007 10:23 am
    1] Take the left side panel off.
    2] Disconnect the air boot from the back of the carburetor.
    3] There is a bolt attaching the bottom of the airbox to the frame via a clip. It is behind the frame. (see pic in my garage). I don’t remember but there may be another one under the seat. You may need WD40 on the clip; be careful not to damage the airbox. I did not need to completely remove the screw.
    4] Remove the crankcase vent hose located on the battery side of the bike.
    5] Remove the mud flap from the back of the airbox.
    6] Wiggle the airbox out. You do not need to remove the battery box.
    when ajusting the shock,
    Use a stand to get the back tire off the ground.
    A little goes a long way so test the bikes height before you button every up and ride.
    kawasaki klx 250
    hmf exhaust
    tusk bark busters
    progrip 790 grips
    removed snorkle
    removed everything except head/tailight
  • crf100rider21
    by crf100rider21 » Sat Apr 28, 2007 1:00 pm
    Tyler knows how to copy and paste!
    Ben
    Honda crf230
    big gun pipe
    Power up kit
    pro taper bars
    protaper bark busters
    Mazda b2300
    tinted windows
    custom sound system
    flo tec with dauls commin out the back
    gal8x
    by gal8x » Sat Apr 28, 2007 7:07 pm
    :lol: :lol: :lol:
    230@#)
    by 230@#) » Sat Apr 28, 2007 7:08 pm
    Quote- I don’t remember but there may be another one under the seat
    I just raised my suspension yesterday and yes there are two bolts that are under the seat but the bolts are right under the edge of the seat so you dont have to take the seat off. There are some wires that go right over top of the two bolts just bend the little rings the wires are in up and you can get the two bolts easy.
    gal8x
    by gal8x » Sat Apr 28, 2007 7:24 pm
    230@#) wrote:Quote- I don’t remember but there may be another one under the seat
    you are correct :!: :D
    they are located over the battery box. 8)
