LadyMud yo girl, whatup? (sorry about the in-fighting
LadyMud wrote: Im trying to get honda to send me a service manual=), i feel like a newb hearing all this talk man....lol
Don’t sweet it babe.
LadyMud wrote: got a new air filter, but for some reason there wasn’t an option for me to screw in the air filter the way they did, so i left the old one on...
eh? That don’t make sense. Did you transfer the air filter holder to the new filter?
If so then give me the brand name and a part number & I’ll see if you got the right one.
LadyMud wrote: I also purchased new rev box..installed that...
I liked mine too at first, but I did some testing and found the stock CDI to be better.
I recommend you put the thing on Ebay and lets spend the money elsewhere.
LadyMud wrote:and a new needle...i havent done that yet..i think that might take a little more effort to do..or just a bit more sunlight...and im not quite sure how to do that...i dont have the service manual..
LadyMud wrote: on the needle, it just says c30f on itself... i mean i could give you the part number 16012-kps-921.
Yes that is the power-up needle.
The manual is a must.
The needle is optional but you need to change the clip position if you are going to use the stock needle. Once you have the carb apart I would recommend you install the power needle, (Honda designed it and they do have the dynos and engineers to use them).
Please note I don’t see where you installed a new main jet. You need to do so sooner than later. You do not want to create an overly lean condition in your fuel mixture.
After that you will need to adjust the fuel/air screw to retune the carb. To do that you need to replace or modify the stock screw because it requires a special $100 tool.
Try slipping something over it like a hose so you can turn it while the bike is running.
LadyMud wrote: i would consider myself a slight bit aggressiveas a rider =)..so what do you suggest for the sprockets? change em both, or just keep the rear end?
it depends on your style of ridding. If you want the bike to stand up on demand then I recommend the 428 conversion.
If you want to take advantage of the 230s six speed gear box then by all means change the drive ratio. Start with a 14tooth primary. If you like it but want more then try a 15 tooth.
I ride in mostly in woods, some open ground, some steep embankments. Wheelies are fun but I want more. That is why I also own a 450x.
I have raced against my 450 and in the tight woods the 230 smokes it. (while you other guys are thinking it is all about the rider let me just tell you that my brother is a natural, he knows these woods as well as I do and he is by far the better rider).
Some times our posts drift off topic but you came to the right place to lern about Honda bikes.
Luck
