I'm new here, somewhat new to the world of dirt bikes.
Though I'm in my 40's and use forums for a range of other interests.
Last month I stepped up from a DRZ250 that I was using to lean on, to a 2012 250x with 25 hours on it.
Over all I'm very happy with it, though it does have the bog in the low rpm range.
After doing a lot of reading on the issue here and other sites.
Seems like re-jetting is a good first step.
To that end, I've ordered a JD Jetting kit from here which has just turned up
Opening up the air box is easy, and my friend is going to help with the install of the jetting kit.
The guy that had this bike before me, had removed the spark arrestor, and cut off the end ring that would hold it in place.
Though I have both parts and can fix that.
With all that said, what I need to know is...
1: On this bike/setup, when I read about the baffle or the diffuser has been removed, are they taking about the same thing ?
The "stuff" inside the spark arrestor.
2: With the jetting kit, I'm going to open up the air box, but with the pipe, best to leave all that stuff off/out.
I can live with the sound with out it installed, but if it doesn't need to be in the mid/high 90db range, then I wouldn't.
I also want to stick with the stock pipe for now, it will be some time (if ever) I could out ride the power it's got now.
But the bog is a right PITA for where and how I ride, so it must be fixed.
Thanks
